Please see attached PDF file.
I'm unable to select the fill region. I thought it's the invisible line not checked under VV but it is.
So what's causing the fill region that can be selected and highlighted.
Solved by diesellam. Go to Solution.
Hi - even with a crossing window - right to left - will not pick it up?
LD
Can't tab it either. It's just a simple filled region I did long time ago, and now all of a sudden it can't be selected no matter what I've tried.
The issue is that you have the linetype for the filled region boundary hidden within the view. Unhide all linetypes and it will become selectable
