I can't open the file (other files can be opened). the backup file dose'nt opened too.
I get the message:
"unable to open the file because of unresolved pointer references. please contact autodesk support."
I'm using REVIT 2015 student version.
Please help me... very important file.
This is a new error to me...
You can try clicking the 'audit' check box in the open dialog. This will often resolve errors on open.
Hi there,
Hopefully you are a subscription customer seeing as you on Revit.
The only way you going to get around a error like that is to log a support case via the Autodesk subscription centre & ask for FTP details allowing your Revit model & Journal files.
I know this sounds like a long shot, but I have done this on a number occasions with a surprsingly high success rate.
Hope this helps
Regards
Enslin
