I'm trying to add keynotes in a FAMILY file for a family I downloaded from RevitCity. I get the following message:
Unable to load Keynote data; the file has either been moved or deleted. Check the folder location of the keynote table in the Keynoting Settings and change the folder path if necessary.
I can find Keynoting Setting when I'm in a project, but I have yet to find how to get there when I'm in a FAMILY file. Surely, there's a way to do this when you are creating siblings in the FAMILY file.
Thanks for any help provided!
Solved by enslinj. Go to Solution.
Hi there,
Within the family enviroment the keynote settings are found here:
Manage Tab
Additional Settings
Keynoting Settings
Regards
Enslin
