I have just started working on Revit 2013 according to tutorial provided by AutoEd -http://www.youtube.com/watch?v=lJyzZy5h_b4&list=PLB3DC6A8DE288C013&index=4
In this i have done all the things according to the video but still i am unable to load families for columns as it is showing that some or all the family files you slected can't be loaded. Please help me.
Sunil
Hello - you will need to make sure you are in the column command when loading columns or go through the Insert tab - Load Family.
Some components are very picky on how they are loaded into revit. You cannot load them using other options.
You could also open the family and do a Load into Project - this should get it into your project.
LD
OK, this is my situation:
I tried loading a door, and it would load it would also appear under the doors families, but I cannot place it. Also if i click on the doors button on the ribbon it would not appear in the properties palette, I have tried this several times but no family type would work, it seems like we can only load so many and it would quit on me. I have had this problem for two projects now. To make a long story short: the families load but i can't see and place them using the ribbon button.
Help on this would be greatly appreciated!!! Thanks a lot!!!
