Un-pick Lines
3 REPLIES 3
martysaid2009
1264 Views, 3 Replies
Un-pick Lines
Hi there
Basic question - when you have selected a line using 'pick lines', is it possible to unpick that line (if you have picked the wrong line for example)?
Many thanks
Marty
Marty Said
Revit Architecture 2014
3 REPLIES 3
No, not that I know of. You will just have to delete the incorrect line manually.
Chris Needham
Whangarei
New Zealand
ameadows
in reply to: martysaid2009
Ancient question but no answer... I use 'Ctrl Z' to unpick the last line selected or 'delete' key for previously picked lines (it changes the selection arrow to a  selection arrow with a cross)
yeah Ctrl Z is the way to go!
