Please expline what types of walls to use LOD 100,and next stages until LOD 300.Because i start with generic walls in LOD 100,but after the LOD 100 I feel generic wall is not fine for working drawing .But i dont have any idea what types of walls should i choose next stages
Solved by David_W_Koch. Go to Solution.
I MEAN "LOD -LEVEL OF DESIGN FROM CONCEPT TO WORKING DRAWING "
If you are at an early, schematic stage where LOD 100 is the only requirement, and if you truly have no idea what the construction of the final Walls will be, then a generic, single-layer Wall is acceptable, but just because the required level of development is only 100 does not mean that you cannot use Walls of a greater level of detail (particularly if you are fairly certain that the final construction will be that particular Wall type). It does mean that anyone else making use of the model should not base any of their work on the greater level of detail provided (until the project progresses to the point where that level of detail is required).
I see no point in making extra work by starting with generic Walls and then swapping in more detailed Walls if you know what the final Walls will be up front.
