Type of parameter
5 REPLIES 5
rimutaka
533 Views, 5 Replies
Type of parameter
I created label for title block but unsure what type of parameter will be used.
The label is for " City and Post code", eg: Auckland 1001
Can someone help me?
Thanks a lot.
5 REPLIES 5
L.Maas
in reply to: rimutaka
Not sure exactly what you are looking for.
When adding parameters to a title block they have to be shared parameters.
You could create you own shared parameter named "City and Postcode" or create two parameters "City" and "Postcode".
As both are containing text the parameter should be of the type "Text"
If Postcode is always a number you could have that parameter of type number or integer.
Does this answer your question?
Louis
Please mention Revit version, especially when uploading Revit files.
in reply to: L.Maas
yes, It works.
Another question, how do i classify type of parameter for "date", eg: 28 - 09 -2014??
Many thanks
cbcarch
These parameters are usually placed in Project Information--Manage Tab>Project Information.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
L.Maas
Revit does not have a date type. So could follow two approaches
1-Use a text parameter and have values like 2014-09-30
2-Use three parameters (like DateYear, DateMonth, DateDay) which could be of the type integer or text.
Option 1 is most simple and usually sufficient. You have to make sure that user fill them correctrly.
Louis
rimutaka
in reply to: L.Maas
