Type Catalog
1 REPLY 1
353 Views, 1 Reply
Type Catalog
I am trying determine what the correct syntax is for parameters other than the usual lengths etc. I have so far worked out to use the heading "parameter##other##" but would like to know what to use for a "yes/no" parameter?
for example:
,Height##length##millimeters,Width##length##millimeters,Fixed Half##other##
18.18,1771,1800,no
the yes or no does not work in the last column, is there another way of doing it?
1 REPLY 1
loboarch
Here is a recent blog post about creating type catalogs.  This link goes to part 2 so you might want to investigate the blog for part 1.
http://do-u-revit.blogspot.com/2010/07/inside-type-catalogs-part-2.html?utm_source=feedburner&utm_me...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
