Use the linework tool to change the way lines are projected. Looks like the
tip of a fountainpen in the toolbar, next to the paint bucket. Select the
linetype you want to change to in the drop down list. Once the linework
tool places the line, you can adjust the length with the blue handle dots if
necessary.
"Chris Broda" wrote in message
news:4124af9b$1_2@newsprd01...
> I have two wall types that sit one on the other. The exterior cladding is
> the same, but the backups are different for each.
> When they are looked at in section, there's a heavy line defining the
bottom
> of the top wall and the top of the bottom wall. Can that line be
eliminated
> yet still keep the heavier outline for the exterior and interior surfaces
> Particularly, since my exterior cladding is the same, I want these to
join.
> TIA
> Chris Broda
