Have you tried to override the visibility of the View?
Make your view a Medium or Fine level of detail, so the wall's materials
show up.
Type VV, and on the visibility graphics overrides window, select "Walls"
category and expand it, turn off "Common Edges".
The only concern is, if your tag is reading material, what prevents you
from tagging the finish, instead of the structure?
Sean D Burke, Assoc AIA
Technical Consultant
Autodesk Consulting - Building Solutions
visit - www.autodesk.com/consulting
gsucci wrote:
> Thank you Aaron,
> yes, that is the problem.
> However, if you think about it, finish plans will need to show different finishes on the same wall, but maybe different sides, therefore a single material for the wall would have not worked in all occasions.
> I am trying to find a unified finish tagging system, and the most logical way is to use materials and their identity built-in parameters. I am trying to use the least amount of custom parameters.
> In this way, setting the view to medium allows me to access all layers of the walls, which, if properly built, can show specific materials on either sides. The extra lines of the walls' layers are absorbed by the line weight, expecially at 1/8" scale, so the extra details are not a big problem.
> For walls painted only partially, the only way I found is to split the wall in two, and assign a different type (and therefore, material) to the portion of the wall I want to paint differently. Unfortunately, the split region tool does not work in plan view, that is, once the wall is split, the tags do not read the split face material. This also does not work if you simply paint a face of a wall and then try to pick up the new material with a tag. The tag will read the material under the structure of the wall, and not the material painted with the paint tool.
> But, all in all, I think I am pretty much there, since floors now work perfectly using the split face tool, and painting different materials for each floor finish.
> I created a material tag, with different types for walls, floors and millwork material tagging. In the future, we will be able to complete all information in the material parameters, and create a complete schedule of finishes for the project.
> Thank you again,
> any further advices or comments on finish plans is welcomed, of course,
> regards
> gio
