Revit Architecture
Revit Architecture
Active Contributor
0 Kudos
Post 1 of 3
TWO DIFFERENT TAGS FOR WINDOWS
196 Views, 2 Replies
07-21-2012 05:35 PM
Hi:
Is it possible to have two different tags for windows? In some I'd want to see the description, and in others only the mark. It seems that I can only load one tag for windows at the time?
Thank you!!!
Silvia
use the same tag with two Types in it.  One Type will show the Mark, and the other Type will show the description.  Place the tag, then switch it using the type selector.  You will have to edit the window tag to add the descriptor lable, and set up the visibility for the Types.
Employee
53 Kudos
Post 2 of 3
Re: TWO DIFFERENT TAGS FOR WINDOWS
07-22-2012 09:16 AM in reply to: ssoonets
Scott D Davis
AEC Technical Specialist
North American Sales
Want Revit Content? Go to http://seek.autodesk.com !
Active Contributor
0 Kudos
Post 3 of 3
07-23-2012 02:56 PM in reply to: davissc
Thank you!!!
It took a while to discover how to hide each label, but at the end I did it!!!
Silvia
