Thanks Paul. The way your framing plan looks in the customer gallery is
exactly what I am trying to accomplish, but I am having no luck in achiving
it. I am confused on how in the default template they set the bottom clip
plane below the cut plane and I cant do that on my plan. I have lower, main
and upper levels with roof levels. So when I try to do the lower level
wall/ main floor framing and it is in hidden line it doesnt show the framing
but when it is in wireframe it shows as single lines. I would prefer to see
all of the linework because we use different framing materials and it is
beneficial to see them graphically. I set the top plane ( 0'-0" main
level ) cut plane ( -2'-0" Assoc lower ) bottom ( -4'-0" Assoc lower ) and
view depth ( -4'-0" Assoc lower ) Again Paul I would like mine to look just
like the one you did in the cg. Thanks for all the help.
John Fleming
"Paul Monsef"
wrote in message
news:4826696@discussion.autodesk.com...
That depends on what you want it to look like...
For instance, I have levels, 1, 2 and a T.O. Plate - lvl 1 in a revit model.
I would base my framing plan off the T.O. Plate - lvl 1 view and set the cut
plane to -2'-0". the bottom set to something lower than -2'-0"... top @
whatever...
I also like to have the floor above on as an underlay.
Does that help?
Paul Monsef
TSA architects, pllc
"John Fleming" wrote in message
news:4826654@discussion.autodesk.com
