I'm trying to access the tutorial videos at this link http://students.autodesk.com/ama/orig/bim2010/Start.htm for the
Autodesk BIM for Architecture, Engineering, and Construction Management 2011 Curriculum. They are not working, does anyone know where else I can find this series? I'm trying to teach myself and these would be helpful.
Rob
Thank you for the heads-up on this issue. It appears the links at the following location are not currently found:
http://students.autodesk.com/ama/orig/bim2010/videos/index.htm
I have reported this to the Education Community; I will update this thread when I receive an update.
Thank you,
I was able to verify the Education Community is aware of the issue and working towards a fix.
Thanks again,
Many of these videos are now working and the remainder should be fixed today.
Thanks again,
I am trying to use the video lessons in Revit wiki help and they do not seem to be working. I get an error one is stream not found. I have tried to download Flowplayer but I have no way to unzip the file
Rich
