I want to turn my in-place mass walls (sloped or helical) to structural walls but i don't know how to do it. I'm able to do the walls but when i switch it to the analytical view the wall doesn't appear because it's not structural. It's there a way to do in-place mass structural walls. Thanks in advance.
I made some observations on the subject and it seems that turning into structural for non vertical walls is not allowed.
Why I did took this conclusion :
I did the following test:
This means , in my opinion ,that only vertical walls can be used as structural in Revit....Maybe when Revit will promote Sloped Walls this will be solved.....
