Trying to work around Instance Parameters
4 REPLIES 4
Womack
161 Views, 4 Replies
I need to use an instance parameter for visibility of a portion of a nested family. I need to do calculations based upon if the item is visible or not. Is there a way to use an If statement in the instance parameter to set the value of some other Family parameter?
Possibly like if (it is visible) set other parameter equal to 1 ?
4 REPLIES 4
Womack
in reply to: Womack
Still need help with this one.
RevitIt
in reply to: Womack
IF (Parameter = 1, 1, 0)
Womack
in reply to: Womack
Tried this in Revit 8.1, if(Testing = 1,1,0) got the error message, "Improper use of Boolean Expressions". Testing is an Instanced Yes/No expression. It was placed in the formula for an Interger, named Tester. Also tried if((Testing = 1),1,0) I got the same error message.
in reply to: Womack
Yes/No parameter can not be compared to 1. Try the following formula instead
if( Testing, 1, 0)
When Testing is equal to Yes formula result will be 1.
wrote in message news:4942498@discussion.autodesk.com...
