I would like to know if there is any way that the members of my newly created truss family can both look like the elements are actualy connected and also have the lower chord ends cut perpendicular to the floor level?
See attached. Perhaps the structural framing elements have to be edited?
in Project , draw a Reference Plane as you show in you screen shot.
Select the element you want to be cut .. then : Geometry >Cut >1-select the element you want to be cut on the side you want to preserve and 2- the Reference plane...Repeat the operation as long as you want..Moving or rotating the Reference Plane will determine changes of the cut..
Your Name
for cuts that are not only liniar you can use also : Architecture > Opening > By Face . It works fine ...
Your Name
for joining members:
1
Use Cope
2
Use Reference Planes
Your Name
Cope? Don't see that, can you explain further please?
yes, I understand....you are from UK....I think in your menu is another term...is it Notched?
Your Name
Using TAB , select the bar and unpin it . After that , you'll be able tp make stretches....
Your Name
Can you post the file containing the truss or at least a part of it?
Your Name
Have now sussed this out thank you but I wonder if 'Notching Distance' can be universally controlled? Having got the web members to stretch and then 'notch', each member then has a 'Notching Distance' parameter appear in properties which defaults to 20mm. Since I cannot find anything in 'WikiHelp' referencing 'Notching Distance' (accept in connection with stairs) and it is taking a long time to set the 'Notching Distance' of four members in 36 Trusses! surely this must be controlled from somewhere?
