True North angle parameter in TitleBlock
5 REPLIES 5
2784 Views, 5 Replies
Hi all,
In the Tittle Block family I created a true north symbol. you know, the one
with a circle and a bold line from its center.
I then created a parameter with agular label for it rotation against a ref. line.
When this Title Block being inserted in to the project file, I change the angle
accordingly to what I wanted, say 20 degree.
Yes, the bold line rotates as I wanted, but the rest of the lines in the tittle sheet also
adjusted, say being shifted to the right a fair distance of 1/128", very noticeable.
What have I done wrong?
5 REPLIES 5
rosskirby
Can you post an image, or the family itself?
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
in reply to: rosskirby
here we go
rosskirby
Thanks, that made it clearer what you were trying to do.  Here's what I'd recommend.  Start a new generic annotation family, and draw your north arrow there.  Then load that into your titleblock family, and set up your angular parameter.  That should get the whole north arrow to rotate.
Ross Kirby
Principal
Dynamik Design
Thanks, it works now.
Alfredo_Medina
I have written a blog article about a similar North symbol family, with includes a parameter to specify the rotation:
http://planta1.com/forum/entry.php?1-How-to-create-a-North-symbol-that-rotates-with-a-parameter-with...
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
