Trouble importing family into poject
2 REPLIES 2
222 Views, 2 Replies
I am unable to import this planter box i created into the project I am working with. I have attached the planter box family file (rfa) I am working on and and a screen shot image (jpeg) of the planter box once it's imported into a project. I used another planter box template to create my family. Perhaps the file path is not set up correctly. Please help me insert this family file into a project file.
Thanks!!
2 REPLIES 2
Open the Family, then select it and choose Edit Extrusion.
Select Visibility Settings, and check Coarse, Medium and Fine.
Save, then Load into Project, overwrite parameters, etc.
It should now show up.
How do I change the planter file so that when I drag it into the project it places it close to the center of the file. Right now when I drag it in I have to spend 5 min trying to find the small object on the scree. Can I specify this with a path?
