When attempting to print to PDF a view from Revit, I am running into an interesting problem: in preview, the image displays properly, but when the file generates, it is blank, with the exception of black lines on each side of the page. Suggestions?
Hi chadly17,
Please go to “R” button, Options Graphics tab and see if "Use Optimized View Navigation" is unchecked. If so, please check and see if the issue remains.
Please check if you have already installed the recommended drived for your video card from the link.
Please try to a different version of the printer driver, or change settings in the driver to see if the behavior changes.
Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
