Revit Architecture
New Member
lisalldt
Message 1 of 4 (337 Views)
Troubkle placing components
337 Views, 3 Replies
08-26-2010 11:21 AM
Whom ever who can help me with this,
I'm tgrying to place my range hood component in my east kitchen elevation view and revit will not allow it and when i siwtch to the first floor view to add the componenet it places it in sideways but when i switch to an oppisite view such as south or north view my range hood that goes over the stove in the east view it comes up the right way but when i try and move it into the correct view its shows up sideways still whatver shall i do????
*Expert Elite*
LisaDrago
Message 2 of 4 (336 Views)
Re: Troubkle placing components
08-26-2010 11:28 AM in reply to: lisalldt
Can you post an image of it?
is the component based - like ceiling based, wall based, line based?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Active Contributor
bcarriere
Message 3 of 4 (132 Views)
12-15-2012 07:10 PM in reply to: lisalldt
I am having problems with the same component. I downloaded it from Autodesk seek (see attached). How do I get it to display properly in plan and elevation? When I place it in the floor plan, I get this message:
"None of the created elements are visible in Floor Plan: First Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
When I try to place it in elevation, I get this message:
"This type of Component cannot be placed in Elevation or Section view"
I have everything turned on in graphic visibility. What am I missing?
Active Contributor
bcarriere
Message 4 of 4 (125 Views)
12-15-2012 09:22 PM in reply to: bcarriere
I figured it out. It was the view range of the first floor plan. I had to adjust the cut plane offset in the view range dialog.:smileyhappy:
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
