Troffer Lights2X4 placed as elevation view in plan view revit 2014
4 REPLIES 4
jmackniak
578 Views, 4 Replies
Trying to install 2x4 lights in a drop ceiling. When placed into plan view the lights are installed but in elevation view.  How do you correct this so lights lay the way they are supposed to?
4 REPLIES 4
GHASEM_ARIYANI
in reply to: jmackniak
Hi
Please place a picture of your problem.
According to you ,Please follow the following procedure:
1-Choose a light on the project.
2-Click the Edit Family and go to family Editor.
3-Uncheck Always vertical and check Work Plane-Based.
4-thec Click Load into Project.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
jmackniak
in reply to: GHASEM_ARIYANI
jmackniak
Figured it out on my own.  Place on face option, which i believe is a new option in revit 2014
GHASEM_ARIYANI
You have options Place on Face Choose.
