Trying to install 2x4 lights in a drop ceiling. When placed into plan view the lights are installed but in elevation view. How do you correct this so lights lay the way they are supposed to?
Solved by jmackniak. Go to Solution.
Hi
Please place a picture of your problem.
According to you ,Please follow the following procedure:
1-Choose a light on the project.
2-Click the Edit Family and go to family Editor.
3-Uncheck Always vertical and check Work Plane-Based.
4-thec Click Load into Project.
You have options Place on Face Choose.
