I have a site plan with trees which look like two crossed planes when looked in 3D black and white.
I wonder if there is a way to smooth these trees so they look smooth at least during the time that I prepare a PDF of the black and white 3D Site Plan. If this setting can be reverted to the crossed trees after prparing the PDF, that is fine. Also at this time I am working with black and white 3D, so color is not an issue, only the smoothness of the trees.
Is there a setting that can make these trees look smooth?
The trees you see are standard Revit RPC families, which use "billboards" to face the camera when rendering.
When in a "non-rendered" view, such as a black/white shaded view, they will appear as two planes as you describe.
So--if you need entourage families that are "smooth"--you will need to create them in the Family editor.
I'd suggest using a Generic Model family template to create some simple extruded shapes representing a "trunk"
and "leaves".
cheers
