TREES TREES TREES TREES TREES TREES
2 REPLIES 2
deeRbee
431 Views, 2 Replies
I use the unrendered revit model a lot and I like the graphical quality it gives when you apply shadows to the model. This is all fine apart from the tree's. Can anyone tell me where i can find a decent model tree instead of the stick one's which are for rendering. The tree's in the library are too luminious green and i can't seem to change the colour's or shapes of them.
db
2 REPLIES 2
in reply to: deeRbee
We use dwg imports in our tree families and I think they look pretty good. Take a look at this one and I'm sure you can make some to suit your needs. The trick is to make a base file first with the dwgs set in it, then load that into the main plant family, then it will scale up or down with the tree size you input.
deeRbee
Nice one, i like them. Thanks a lot.
db
