hi
Option Transparent In the Family environment Metric Window What does it mean?
Solved by CoreyDaun. Go to Solution.
That affects whether or not you will be able to "see through" the opening in a 3D or Elevation View. If the option is enabled, it will display as a true opening (image: left) allowing you to see elements behind it. If disabled, it the opening will become opaque and block visual (image: right).
Hi
Thank you
