Transparent Option
2 REPLIES 2
GHASEM_ARIYANI
226 Views, 2 Replies
Transparent Option
hi
Option Transparent  In the Family environment Metric Window What does it mean?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
CoreyDaun
in reply to: GHASEM_ARIYANI
That affects whether or not you will be able to "see through" the opening in a 3D or Elevation View. If the option is enabled, it will display as a true opening (image: left) allowing you to see elements behind it. If disabled, it the opening will become opaque and block visual (image: right).
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
Hi
Thank you
