In Revit 2013 - Some elements are displaying as transparent in the 3D Shaded view. All the glass elements are showing through solid parts of the model in 3D shaded view. Please see the attached image. Are there any settings to fix this issue?
Hi, we have on some (not on all) computers the same problem and switch of the hardware acceleration. You could also try to reduce tre transparency of your material to 0, this should work also.
Update your video card drivers and make sure you have all Revit service releases installed.
Ross is right- this is an issue with older display drivers.
Details here:
http://revitclinic.typepad.com/my_weblog/2012/04/glazing-appears-through-walls-in-revit-2013.html
Joe
