Revit Architecture
Member
folkeh
Message 1 of 6 (143 Views)
Transparency in floorplan?
143 Views, 5 Replies
10-31-2012 04:07 AM
Hi
I have just installed update 1 + 2 in hopes that the problem with transparency in floorplan would have been corrected, but sadly it hasen´t been (!).
We rely very much on this function for showing for instance things behind ceillings.
The print raster function is a no-go, because we also need to export plans to DWG files in many cases.
Best regards
Jakob Hansen (Denmark)
*Expert Elite*
Alfredo_Medina
Message 2 of 6 (139 Views)
Re: Transparency in floorplan?
10-31-2012 04:24 AM in reply to: folkeh
Can you please post one or two images describing the current problem and the desired result?
I have not heard before about a problem with "transparency in floorplan". What do you mean by that?
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Member
folkeh
Message 3 of 6 (133 Views)
10-31-2012 04:44 AM in reply to: Alfredo_Medina
Here for test purpose I have made a duct over the ceilling and made the ceilling transparent.
As you can see the duct disapere in the PDF, but only when the entire duct is behind the ceilling!?
Info: Ceillingplan.
        Ceilling hight: 2800mm
        Duct hight: 3000mm
This is clearly a bug that came with Revit 2013. There was no problems prior to 2013!
Screenshot in Revit:
PDF vector print:
*Expert Elite*
Alfredo_Medina
Message 4 of 6 (129 Views)
10-31-2012 04:56 AM in reply to: folkeh
Can you post that sample .rvt file?
Member
folkeh
Message 5 of 6 (113 Views)
10-31-2012 07:10 AM in reply to: Alfredo_Medina
Hi
There is really not that much to share, it´s a very basic setup: four walls and a ceilling.
As said before, there was no problem in Revit 2012, so this post is more a cry to Autodesk for an update that actually addresses this issue.
Best regards.
*Expert Elite*
Alfredo_Medina
Message 6 of 6 (108 Views)
10-31-2012 07:54 AM in reply to: folkeh
Better than posting a cry, it is more useful to post a file, so that somebody can try to detect what is going on.
Post to the Community
New Post
Need installation help?
