Hi everyone! I'm working on a proyect and I need to see if there is a way to get an schedule of the amount of soil that's gonna be removed and if, eventually, can make a "fill" with that soil(or something equivalent). Is there a way of giving volume to the toposurface that may help to the case? I'm actually quite confused in the topo-universe of revit... Thanks!
About cut & fill, maybe you just need to do some readings on those topics in the help documents:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-F9994BBC-027A-41B8-8852-FB33A34C3AC7
About giving volume to a site, in a 3d view activate Section Box, and move the faces of the box until it cuts the topography. It will give the appearance that the surface has a volume.
