I would like for my topo surface to have edges, as if the acutal ground were cut off. In otherwords, I would like to show a surface with volume as opposed to just a potato chip. See my image.
I have noticed that all the videos and images I see of toposurfaces look volumetric rather than a wafer. However, mine look like a chip.
I know two methods:
1. using Section Box -
2. using Massing and Site > Split Surface...you will have a phisical cut
Constantin Stroescu
Thanks for your message. I already trimed the surface and the effect of the scope box is not what I'm looking for. Check this image for what I'm looking for. I want the surface to look like a solid.
I did it with SECTION BOX....Why do you say it doesn't work?...It seems me that this is what you are looking fore...Am I not right? ...Look in the attached file...
Constantin Stroescu
