Hi
My PC has recently been upgraded to Windows 7. Unfortunatley now i ahve only limited fucntionality on AutOCAD.
How can i get the toolbars & command line ?
If i try the 'customise' option, i get the error message attached, it can't find the 'cui' file.
probably acad.cuix got coruppted look in folder
C:\Users\<your user name>\AppData\Roaming\Autodesk\AutoCAD 2010\R18.0\enu\Support
for these files:-
acad.cuix & acad.bak.cuix
make sure autocad is close
rename acad.cuix to acad.old.cuix
rename acad.bak.cuix to acad.cuix
restart AutoCAD
if it does not help? repair autocad installation.
cheers
Moshe
