Toolbar reset
4 REPLIES 4
dgizzim0
8726 Views, 4 Replies
Toolbar reset
Now, Revit is pissing me off again. Has anyone experienced the ribbon shuffling? The normal order is "home" ... "modify". Well, "modify" is now at the beginning. For years I'm use to a specific order. This is not cool.
Does anyone know a fix?
4 REPLIES 4
jim5552
in reply to: dgizzim0
I found the following in Wikihelp.
Use this link to the information below.
There is also a topic "To reset the ribbon and Quick Access toolbar".
Hope this helps to answer your question.
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/0005-Introduc5/0018-User_Int18/0...
dgizzim0
in reply to: jim5552
Did that. Didn't work. But thanks.
see attachment
LisaDrago
Actually if you hold the Ctrl key and click on a tab you can move it whereever you want them to be.
More of a user error then a Revit issue.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
dgizzim0
in reply to: LisaDrago
Awsome! What a stud! It was user error. Your fix worked. The contol key is my friend, but this time, it wasn't.Smiley Happy
