Now, Revit is pissing me off again. Has anyone experienced the ribbon shuffling? The normal order is "home" ... "modify". Well, "modify" is now at the beginning. For years I'm use to a specific order. This is not cool.
Does anyone know a fix?
Solved by LisaDrago. Go to Solution.
I found the following in Wikihelp.
Use this link to the information below.
There is also a topic "To reset the ribbon and Quick Access toolbar".
Hope this helps to answer your question.
Actually if you hold the Ctrl key and click on a tab you can move it whereever you want them to be.
More of a user error then a Revit issue.
LD
Awsome! What a stud! It was user error. Your fix worked. The contol key is my friend, but this time, it wasn't.
