Tool bars playing up
1 REPLY 1
IMAC35
193 Views, 1 Reply
Since yesterday my tool bars are playing up.
For example, select a group to edit and correct tool bars appear then I select a line to modify but the group editing tool bar doesn't change to a right tool bar to modify lines. When this happens I have to restart a computer and it's only ok for first command then frozen tool bar cycle continues.
Please help!!!
1 REPLY 1
damo3
in reply to: IMAC35
Sounds like a common issue solved by updating.
If your using Revit 2013... update to latest. Update 3 will fix this issue.
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
