Since yesterday my tool bars are playing up.
For example, select a group to edit and correct tool bars appear then I select a line to modify but the group editing tool bar doesn't change to a right tool bar to modify lines. When this happens I have to restart a computer and it's only ok for first command then frozen tool bar cycle continues.
Please help!!!
Sounds like a common issue solved by updating.
If your using Revit 2013... update to latest. Update 3 will fix this issue.
