I found a post from 2006 that said toilet partitions were under Specialty Equipment in Revit. I don’t see anything like that in Revit 2015. Could someone please advise where I can find toilet partition families, or if they even exist?
Phil
Hi, I think you cannot find the toilet cubicles in revit 2014 & 2015 in US imperial and US Metric ( i dont know why/what is the reason) but i can find it in Singapore Library. Please find attached files. Hope it helps. Thanks
Might be depending on which library you have installed. Several toilet cubicles etc can be found under the plumbing section in the library. (Plumbing, Arcitectural, Fixtures, Toilet Cubicles)
Louis
Please mention Revit version, especially when uploading Revit files.
