The viewport title is a annotation family. There is no way to scale the
text w/o editing the family. Click on it, select Properties and look at
what it's called. Then go your Project Browser, scroll to Families,
Annotation and look for it. Mine is called View Title. Select it, right
click, Edit. It'll open the symbol and you can make changes to it. Then
reload it.
Hmmm, I'm not sure, did you use a template? Mine came with one called No
Title. I think you can select the view title, select Properties, Edit/New,
Duplicate, give it a new name (No Title). In the dialog box you'll notice a
pulldown menu for Title, change it to None. Select OK a few times and it
should work. I'm doing this by memory.
wrote in message news:5439328@discussion.autodesk.com...
Not sure what you are refering to exactly on the first one. Just to make
sure, I'm not wanting to change scales, just the size of the title itself.
Second - When I do what you say the only choice in the drop down is,
"Viewport: Viewport 1" What am I doing wrong? Thanx!
