OK, I figured there was more to it then that. So, how do I set up such a
'label' on a new sheet? I haven't been able to find much help or a tutorial
on how to set up a custom titleblock from scratch.
"Aaron Rumple"
wrote in message
news:5145782@discussion.autodesk.com...
The sheet number isn't a simple text object - just looks like one. The sheet
number is called a label - it references what is called a parameter. When
you change that text, it will update a schedule of the drawing list. Or
change the schedule and it will change the sheet.
"John B" wrote in message
news:5145675@discussion.autodesk.com...
I have a question about creating a new title block for our company. I have
looked at the sample title block that comes with Revit, and it appears that
the sheet number text etc is nothing but a simple text item. Is this true?
And if so, how does the program associate and change the number when it is
changed in the project directory etc. This is all very confusing to me, and
is something that I definately need to understand and do before I can even
think of starting a project in Revit.
Thanks for any help you can give.
John Beaman
CAD Manager/3d Modeler/Renderer
RNM Design
