PLEASE, I NEED TO UPDATE THE LABEL IN THE TITLE BLOCK WITH THE CURRENT DATE AT THE TIME OF PRINTING THE PROJECT. DOES ANY BODY KNOW HOW TO DO IT? SEE THE ATTACHED IMAGE.
THANKS IN ADVANCE.
ALEX
Select the Title Block family on one of the sheets > Edit Family. Select that label that you wish to update > Edit Label. Verify what the Label Parameter is; for example, by default there is one called “Project Issued Date”.
Then go back to the project. Try to double-click on the specific date you wish to edit, or go to Manage > project Information > project Issue Date, in this example. That is where you would enter the date.
If it is a custom parameter someone created, ensure there is a Project Parameter added, linking to the Title Block parameter you wish to edit. Additional information is available below:
Working with Titleblocks and Sheets in Revit
Using shared parameters for a title block in a projects
Thank you,
Thank you for your answer. My question is if using the label Sheet Issue Date in the title block is possible to update automatically when sending the sheet to the printer.
Alex
The only one that updates automatically is the “Date/Time Stamp”, which will update actively in the project.
Thank you,
I used that label, but we don't need the time and tried to put a masking region on the time area but didn't work. Is there something different to make that show the date only?
