“Tick mark” size,
2 REPLIES 2
JamaL9722060
3364 Views, 2 Replies
“Tick mark” size,
“Tick mark” size,
I’m wondering if there is a way to set a particular length for the “tick mark” the same way we do in the AutoCAD. Sounds that the options are limited to those in the list in the Revit.
For example, I need the length of the tick to be 1.5mm instead of 3mm. How this might be achieved?
Thank you
Best
Jamal Numan
2 REPLIES 2
Manage>Additional Settings>Arrowheads>Duplicate (duplicate a Diagonal style in the list)
Give it a new name, set the size.  Apply this new tick mark in the dialog box you show in your picture.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/3032-Customiz3032/3042-Project_3042...
Scott D Davis
Sr AEC Technical Specialist
Many thanks for the help. this is very useful.
best
Jamal
Jamal Numan
