“Tick mark” size,
I’m wondering if there is a way to set a particular length for the “tick mark” the same way we do in the AutoCAD. Sounds that the options are limited to those in the list in the Revit.
For example, I need the length of the tick to be 1.5mm instead of 3mm. How this might be achieved?
Thank you
Best
Solved by scott_d_davis. Go to Solution.
Manage>Additional Settings>Arrowheads>Duplicate (duplicate a Diagonal style in the list)
Give it a new name, set the size. Apply this new tick mark in the dialog box you show in your picture.
Many thanks for the help. this is very useful.
best
Jamal
