I am trying to thicken my concrete slab at each depressed footing (3'x3' - 4" below bottom of slab). Is there a way to acheive this so that my building and wall sections show the slab thicker when cutting through these locations? I am planning on using filled regions to visually make this happen if there is not a way to model it that is feasible.
JJR
Solved by ccollins. Go to Solution.
Try using a Slab Edge. You load ( or create a custom ) Slab Edge Profile and then click on the edges and it will model
a slab edge at each face of the floor slab you select.
Note: You will have to break up your Floor Slab at the column/footing locations to use the Slab Edge tool.
cheers
Of course! Thanks for the guidance. Sometimes the sometimes the solution is so clear you see right through it.
