Hi, I just started to get this error with one particular revit file. I found a few references to similar errors, but none of the strategies I found managed to solve the issue. If I click continue about 6 times, it goes away and I can work OK but it comes back next time I open the file.
Anyone know for sure what causes this and how to resolve it?
- Mick
This type of error pop up when there is conflict with drive name with your PC. Revit.exe is looking for some file that is not resolved while starting the program. Most likely, this could paths defined in OPTIONS. Please check in COMPUTER MANAGEMENT > DISK MANAGEMENT and find the name of drive same as your shared drive. You might want to rename the drive and remap the shared drive. Hope this helps.
