Hi
When file From Revit to AutoCAD exported Section Line is not export and show the DWG file.
I tried to change exporter layer But it does not.
Solved by constantin.stroescu. Go to Solution.
It will appear in AutoCAD file if the section View is placed before on a sheet and it is tagged with the name of the sheet in Revit
Your Name
Hi
Very thanks for your response.
But why placed the sheets?
I don't know ...Maybe because after placing on sheet , Revit considers the section to be complete . Anyway , it is better to Export sheets then Views especialy for 3d as these can not be export cropped in AutoCAD....
Your Name
Among the options for exporting to .dwg, on the General tab, there is an option to hide those references views that have not been placed on sheets. The default value is ON. That's what makes those unreferenced sections disappear.
Hi Mr.Alfredo
I am very grateful for your reply.
hi
We can With change the Section symbols They're set in the The plan view.
