The “level” indicators are not cropped exactly based on the “crop region”,
In the screenshots below the “crop view” doesn’t crop the “level” indicators exactly as they extend outside the “crop region”
What might be the reason?
Thank you
Best
Jamal
You might try using a Scope Box, which will automatically controll the ends of Levels and Grids.
Place a Scope Box around your building, in an overall Plan View. Highlight the Scope Box, and then give it a name.
(it will be Scope Box 1 by default.)
Then select the Levels and Grids and under Properties check the box under Scope Box.
All Levels and Grids will now be automatically controlled in all your views.
Many thanks for the answer.
I tried the “scope box” but the levels are still extending outside the box!
Why they are not cropped based on the box?
Please, have a look on the screenshot below
Did you select the Level, and then choose the Scope Box to associate it with?
many thanks ccollins. I’ll try it and see if it works with me
best
Jamal
