Hello to all
I have a real problem in this application and those for
These problems demand a solution that I can help.
1-In this column with my software, how do I connect to the wall so that
The walls, columns and layers are clear.( Column and wall of one example of this problem.)
2-How can I view the floor plan of the steps separately do automatically, such as Grid
3-Plan view of the stairs when we look at the architectural design should be
Hidden lines are lines with a stepping stone to show the software but I could not find a solution.
4-I plan on a scale 1 / 100 was drawn and measurements I have found it ،When I plan to scale 1 / 500 will change, and
Hatch measurements do not automatically change
If the AutoCAD software is possible.
To better understand the problems I've put the images below.
Many thanks to you all
