I am tryingto figure out why Revit will not let me unbold the numbering system in a text box I have. The first line is bold and the rest is not. I have deleted the numbers and reinserted them and I have converted the whole text box to unbold and it still keeps the numbers in bold. Any ideas as to why this is? I also am curious if there is any way to justify the text both left and right. The quick look up I did gave me the answer of no, but maybe someone knows something I dont. I have attached a photo of my text in case that helps. Thanks in advance.
Solved by constantin.stroescu. Go to Solution.
you can make two kind of settings for text:
The Paragrah Format (Bullets,Numbers, Letter ) can be controled only from 1.
I've made a screecast on this subject:
https://screencast.autodesk.com/main/details/3d28d0bb-7469-4895-a72f-db2512a2f6da
As for aligning both left and right as in Microsoft Word...I see no option
Anyway there is an addin: Text Generator from Exchange Apps that allows more options for texts- ( but not this one)...
Constantin Stroescu
Hi cjp--
Not sure if your problem was completely solved yet, but here's what is probably going on:
1. Click on your text note that has weirdly-bolded numbers and place the cursor anywhere in the text.
2. Press Ctrl-A to select all the text in the note.
3. In the ribbon, click the Bold button to remove all boldness from the note. Everything should now be non-bold, including the numbers.
At the end of each line in a bulleted list there is a "hidden" character that controls the bullet of that line. If you select just that hidden character and click bold (or italic) the override will be applied to only that bullet. Ctrl-A selects all the text in the note, including those invisible end characters.
As for your request to have both left and right justification. That's a popular request and we hope to implement that in a future Revit release!
Thanks for your question and request,
Trey
