Revit Architecture
jdukc
Message 1 of 5 (171 Views)
text disappears during plotting
171 Views, 4 Replies
08-28-2012 07:13 AM
Hopefully someone else has run across this and has an answer.
I'm plotting multiple sheets in revit 2011 (doesn't matter if it's 2 or 20,)the first sheet comes out fine, but all the rest has text / annotation that has disappered.  Text in the title block, elevation markers, section markers, and column bubbles.  The markers appear, but the text doesn't.  Anybody know why?  My work around currently is to plot to pdf and then plotting the pdf.  But this is a step that I shouldn't have to do.
Distinguished Mentor
Caddman13
Message 2 of 5 (136 Views)
Re: text disappears during plotting
08-31-2012 05:01 AM in reply to: jdukc
What are you plotting to?
I had a similar problem plotting to a KIP.  It turned out that KIP updated some drivers for Windows 7 and Revit that took care of it.
Product Support
fernanda.firman
Message 3 of 5 (129 Views)
08-31-2012 09:05 AM in reply to: jdukc
Please let us know what plotter you are using.
Have you updated the printer's drivers?
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
jdukc
Message 4 of 5 (123 Views)
08-31-2012 10:22 AM in reply to: fernanda.firman
plotter is HP Designjet 4500 and yes, I updated the drivers.  The text is disappearing on all machines here.
Caddman13
Message 5 of 5 (119 Views)
08-31-2012 11:13 AM in reply to: jdukc
HP.  They have that Universal print driver that isn't so good.  We had to roll back to an older Post Script driver to get that work properly for our 1200 DesignJets.
Announcements
Need installation help?
