One optin would be to use the modify roof command by making a flat roof and changing the elevation of the grips. This will sometimes give you the shape you want, but add unwanted lines in the plane of the roof surface. The shapes you have are pretty simple so this may work.
Another option is to create a conceptual mass of the shape you want and then select roof by face.
