Temporary Dimension
2 REPLIES 2
GHASEM_ARIYANI
253 Views, 2 Replies
Temporary Dimension
hi
You can Temporary Dimension We set When the We choose Wall Back to back Be displayed.
Not to be manually Drag it to a solid blue It automatically )
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
CoreyDaun
in reply to: GHASEM_ARIYANI
I do not believe that this is possible to set automatically. If one sets the Temporary Dimensions to measure from the Wall Faces, it will place a Temporary Dimension to measure between the nearest Wall Face as depicted in your image. You'll have to continue to drag and reassign the witness lines manually to achieve your goal, unfortunately.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
Yes you are right
However, we need Sometimes the As temporary Dimension The exterior walls face And sometimes internal wall face.
Such as set is Temporary Dimension doors and windows.
